Up to 20% off select tools
Guides
Ask a Question
There are no questions. Be the first to ask a question!
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The Flydigi Direwolf 2 is a cross-compatible controller, meant to connect to many consoles. It was released on 02/20/2025 and is currently not being sold by the original company. The controller has sold hundreds of copies, often being found on resale websites. The controller is widely accessible in many countries around the globe due to global resell platforms, often ranging between $40 to $80 from third-party websites. The target market for the controller is budget-conscious gamers who desire high end controller features for a low price. The Flydigi Direwolf 2 is part of a family of Direwolf series controller, improving upon the last iteration of the controller by adding Hall effect triggers, better triggers, and higher battery life. The next controller in the series, the Flydigi Direwolf 3 improved upon the previous model by adding 1000Hz polling rate and upgraded Hall effect sensores.
This controller uses different connection methods such as wired cable connection, Bluetooth, and can also be wireless. This controller has 2 extra back buttons to enhance the user's experience.
This controller has customizable buttons, allowing for user formatting of the controller, which can be found on the Flydigi website.
Identification
The controller is approximately 155 x 103 x 65 mm (6.1 x 4.0 x 2.6 inches). The controller can be distinguished by its unique matte white shell and textured grips on the back. This controller should have the name of the company on top, also having no audio jack on the bottom. It features two unique Hall effect triggers located on the back of the controller and distinctive blue anti-friction rings around the joysticks. Model information that can be located on the sticker found on the back/underside of the controller.
Technical Specifications
The Flydigi Direwolf has a nonslip surface to be more comfortable, also using precise and responsive Hall effect joysticks. The controller is an approximate weight of 378 g.
The controller has 3 modes of connection: 2.4GHz USB Dongle, Bluetooth 5.0, and Wired USB-C. The controller has an 800mAh battery (approx. 15h+ life), and 500Hz/300Hz (wired/wireless) polling rates.
The controller has latency of approximately 8.4ms (Wired), and 13.1ms (2.4GHz wireless).
Additional Information
Official website of the controller, Direwolf.
Deep review of controller on youtube.
3rd Party site to purchase
Author
with
Adan Lopez
157 Reputation
0 Guides authored
Past 24 Hours: 2
Past 7 Days: 29
Past 30 Days: 157
All Time: 886
