Battery
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background:
The Arlo Pro VMS4430 is a wire-free home security camera kit released by Netgear in late 2016 as part of the first generation Arlo Pro lineup. Designed for flexible, DIY surveillance, the system includes four rechargeable 720p HD cameras, a base station with built-in siren, and optional USB local storage. Each camera features a 130 degree field of view, night vision, PIR motion detection, and a two way audio, making the system suitable for indoor and outdoor use. The VMS4430 was sold globally through major retailers and targeted homeowners, renters, and small business owners who wanted a high quality, cable free, security setup. At launch, the four camera bundle was around $499-600. The device replaced the original Arlo, improving on it with rechargeable batteries, audio support, and better motion detection. Later models like the Arlo Pro 2 and Pro 3 increased resolution, added continuous recording options, and refined power features, eventually making the Arlo Pro VMS4430 discontinued by 2023.
While the VMS4430 had easy installation, weather resistance, and reliable motion triggered recording, it also developed several well known issues over time. Common complaints include batteries refusing to charge and many more problems like that. Long term exposure sometimes led to battery swelling or corrosion, app updates could have caused connection or compatibility problems, and these added to the platforms decision to discontinue. Despite these challenges, the Arlo Pro VMS4430 remains widely used today and continues to be a popular candidate for repair, because of its modular design, replaceable batteries, and still functional feature set.
Identification:
The Arlo Pro VMS4430 can be identified by its model and kit number, as well as several distinctive physical features. Each camera in the system is labeled as model VMC4030, typically printed on a sticker inside the battery compartment beneath the removable rear housing. The base station included in the kit is model VMB4000, identifiable by its white, rectangular body, front facing LED indicators, rear Ethernet port, and dual USB ports for optional local storage. The full system bundle is labeled the VMS4430, indicating its a four camera kit. Arlo Pro cameras have a characteristic glossy white exterior with a black front faceplate, a rounded rectangular shape, and a magnetic mounting area on the back.
Technical Specifications:
Camera Model: Arlo Pro VMS4030
Resolution: 720p HD
Field of View: 130 degrees
Video Features: Night Vision, motion triggered recording, H.264 encoding
Audio: Built-in microphone and speaker with two way audio
Power: Removable/rechargeable 2440 mAh Li-ion battery; optional AC adapter
Weather Rating: IP65 (indoor/outdoor use)
Connectivity: 2.4 GHz WiFi, magnetic charging contacts
Base Station: VMB4000
Dimensions: 3.1 x 1.9 x 2.8 in
Weight: 4.8 oz with battery
Operating Temp: -4 degrees to 113 degrees F
Cloud Storage: 7-day rolling cloud storage
