Arlo Pro VMS4430 Lens Assembly Replacement
    1. Arlo Pro VMS4430 Lens Assembly Replacement, Battery: step 1, image 1 of 2 Arlo Pro VMS4430 Lens Assembly Replacement, Battery: step 1, image 2 of 2
      • Press down on the arrow button
      • Pull back on the case to open the framing.
      Ask FixBot
    2. Arlo Pro VMS4430 Lens Assembly Replacement: step 2, image 1 of 3 Arlo Pro VMS4430 Lens Assembly Replacement: step 2, image 2 of 3 Arlo Pro VMS4430 Lens Assembly Replacement: step 2, image 3 of 3
      • Pull back on the white tab on the battery, and pull the battery out.
      Ask FixBot
    1. Arlo Pro VMS4430 Lens Assembly Replacement, Case: step 3, image 1 of 1
      • Remove all four 5.5mm corner screws using a T5 Torx screwdriver.
      Ask FixBot
    2. Arlo Pro VMS4430 Lens Assembly Replacement: step 4, image 1 of 2 Arlo Pro VMS4430 Lens Assembly Replacement: step 4, image 2 of 2
      • Separate the front from the back housing.
      Ask FixBot
    1. Arlo Pro VMS4430 Lens Assembly Replacement, Lens Assembly: step 5, image 1 of 3 Arlo Pro VMS4430 Lens Assembly Replacement, Lens Assembly: step 5, image 2 of 3 Arlo Pro VMS4430 Lens Assembly Replacement, Lens Assembly: step 5, image 3 of 3
      • Remove the four 3.0mm screws using a Phillips #00 screwdriver.
      • Remove the camera module.
      Ask FixBot
    2. Arlo Pro VMS4430 Lens Assembly Replacement: step 6, image 1 of 2 Arlo Pro VMS4430 Lens Assembly Replacement: step 6, image 2 of 2
      • Remove the four 4.0mm screws using a Phillips #00 screwdriver.
      Ask FixBot
    3. Arlo Pro VMS4430 Lens Assembly Replacement: step 7, image 1 of 2 Arlo Pro VMS4430 Lens Assembly Replacement: step 7, image 2 of 2
      • Remove the protective metal covering.
      Ask FixBot
    4. Arlo Pro VMS4430 Lens Assembly Replacement: step 8, image 1 of 2 Arlo Pro VMS4430 Lens Assembly Replacement: step 8, image 2 of 2
      • Remove the two 3.0 mm screws using a Phillips #00 screwdriver.
      • Remove the lens.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 71
All Time: 418
