Fifth generation of iPhone. Repair of this device is straightforward, and requires screwdrivers, prying tools, and patience. GSM/CDMA / 16, 32, or 64 GB / Black or White.
2946 Questions View all
Poor wifi signal after screen replacement, which parts to clean?
It is recomanded to clean all metal to metal contacts after a repair. Which parts is relevant to clean if the only problem is WiFi?
And also which tool should I be using for the cleaning?
A swab, cloth or something else?
Hope you will help!
Rgds Kasper
Comments:
Anyone who is able to help?
I allready have a bottle of isoprophyl alcohol.
Hope to get an answer
Rgds Kasper
by
check also the longer screw at the top of the logic board..it should have a little metal edge on the board that can be lost. Tighten or loosen the screw to make contact and see if that helps
by
The longer screw on the top of the logic board.. Aint I Right when saying thats in the iPhone 4, not the iPhone 4s??
by
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
U might of broke off one of the very delicate pieces of metals that touch the frame. Its connected to the loud speaker (black parts near dock connector).
Comments:
There should be 4 thin ones. you will only see 3 if there all there and one bellow the smart board.
by
Add a comment
Add your answer
Kasper Andersen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 680
