Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1169 Questions View all
Question Closed
Water damaged, hung up on the USB/iTunes screen
After drying out my Iphone 3g,
it just has a constant screen of a usb cable with an arrow pointing to the itunes symbol. I have tried connecting it to itunes and restoring But nothing happens, it just keeps keeps the arrow pointing to the itunes symbol.
Does it need to dry out more? or do I need to download Itunes again???
if is the battery do I have to take to an Apple store to get a battery?
not the At&t store, right?
Add a comment
1 Answer
Cathy Gianella, good thing you let it dry out. The first thing to do, or specifically not to do, is to continue to turn it on. I suggest you clean your iPhone according to this guide. Letting it dry out is good, but it will not prevent failure due to corrosion damage, down the line. After it is properly cleaned, replace the battery. The battery is available right here, as well as many other places. Here are the guides to work on your phone. Once you got all that accomplished, reevaluate for any further damage. Hope this helps, good luck.
iPhone 3G Battery Image
Product
iPhone 3G Battery
$14.99
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,423
