Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
Phone makes continual clicking sound
My phone is making a clicking sound about every 30 seconds (extremely annoying!). Took the back off and it sounds like the noise is coming from the upper left-hand corner, just below the camera (or around that area).
I have looked at forums online to try and find a fix but everyone else says that when they apply pressure to the phone it makes the sound. My phone CONTINUES clicking at a regular interval.
Also, my battery has been draining at almost 10 times the speed! I have to charge it 2-3 times a day.
What I need to know is what part I need to replace or how to maintenance it?
or if anyone knows how to troubleshoot this issue
Score 3
3 Comments
I'm having the exact same problem! also my phone doesn't hold a charge at all, holds up to 3% then dies again, can this be something to do with the noise coming from the lens??
by
Turn off Google notifications. It will stop ticking.
by
Mine started doing this also but the sound was irregular and seemed to happen when I tilted the phone side to side but only certain ways. I had just downloaded two apps and one of them caused this. After a few minutes using process of elimination problem was solved.
by
Add a comment
Chosen Solution
OK, so I have figured out the problem (I am responding to my own question so that it is archived and other people with a similar problem can possibly benefit).
I tore down my phone from top to bottom and put it back together again. The "nature" of the noise changed slightly; instead of clicking at intervals there was a prolonged buzz with very short breaks in between.
As I described in my question, the noise was coming from around the camera area. Therefore, I removed the camera (with the phone still on) and noticed the sound went away.
Theory:
I believe that the connection between the camera's flex cable and the logic board wasn't making 100% contact. This was either making the power between the two have to jump across the 2 connections OR there was a build up of energy that was being released based on the connection. Hints, the "clicking" noise or whatever other adjective you want to use to describe it.
I can see this problem being an issue with any connection between the logic board. Luckily the camera isn't a vital part of the functionality of the phone and I was able to remove it to troubleshoot the problem.
Goodluck to anyone else out there with a similar issue =]
Score 2
2 Comments:
Check to see if you have downloaded a metronome app. (pro Metronome). If you find it on your desktop, tap to open and then tap the square button at the center of the dial - it will change shape to a 'play' arrow. Check your 'settings' list or 'app' store to see if you can delete the Metronome app.
by
It wasn't metronome because I didn't have that app but it was a different app. Thanks for info, it still helped me.
by
Add a comment
Dood,
Not a chance, google what it takes to arc even 1 millimeter in free air.
1 Comment:
Yeah it's definitely not arcing that caused your clicking, it's probably the moving parts that contribute to the auto-focus built into the iphone 4 camera. Try just replacing the camera, it should fix your issue. Or you can just live without the camera, but you also lose your front-facing camera functionality by removing the rear-facing camera, just a heads up.
by
Add a comment
Mines not really a question but the same problem. My camera doesn't want to focus either. How do I fix that? Or do I just need to take my phone to apple??
Add a comment
I have an iPhone 6 and it only clicks when I talk to someone on a landline phone.
2 Comments:
Same for me and my husband. iPhone 6.
by
It is so annoying but I cannot find any information about this
by
Add a comment
When using maps, I get the ticking noise after she speaks only when my charger is plugged in. If I unplug the charger the ticking goes away until she speaks again. So I unplug the charger after she is done and it stops till she speaks again. Not too bad on long trips, can get annoying on trips with many short turns. It happens with the regular car charger and also the "mophie" charger. I'll work with it ... hate to give up my S4. Barb
1 Comment:
Same with my 4S after navigation instructions with charger. Stops when unplugged. Really annoying
by
Add a comment
Sounds like you have a Metronome app on your desktop. Click on the metronome icon and then click the square button at the center of the dial. Check your settings list or app store to see if you can delete the metronome.
Add a comment
Add your answer
WillTheThrill521 will be eternally grateful.
Past 24 Hours: 6
Past 7 Days: 25
Past 30 Days: 163
All Time: 51,732
