Shop the Holiday Gift Guide
Repair information for Whirlpool dishwashers.
Not spraying during normal cycle.
Whirlpool WDF560SAFM2.
New circulation pump
Filter Clear, Spray arms clear, Manifold clear, pump inlet/return clear.
Ample water when running
No Error Codes F- E-
Works perfectly during a maintenance cycle but water only dribbles out of both sprayers on any normal cycle
Any ideas?
2 Comments:
Hi @kentrhodes44149
Do both arms rotate albeit slowly?
If only one moves it could be a faulty diverter or diverter disc.
Have you tried just a water only wash i.e. no detergent or rinse aid to check if the arms rotate normally i.e. strong water pressure out of arms?
If they do it could be a problem with air getting into the pump from the dispensers
by Share
It might be the rotating diffuser plate. It sits firmly on the motor axis and doesnt look worn at all but i will find it askew when I open it up to look at it. It anything supposed to hold it down? There arent any clips or catches that seem to hold it in place
by Share
Add a comment
1 Answer
Hi @kentrhodes44149
There's a small slot located in the hub of the diffuser that lines up with a spline on the end of the shaft that should hold it in position.
Check that the diffuser stays in position and can't move unless the shaft moves.
Here's an image of the diffuser used in your model. The arrow is showing where the slot it.
(click on image)
Note: Most parts suppliers call it a diffuser, but the supplier that I copied the image from calls it a diverter plate (and also a suction plate) but the part number shown is the same one shown by all suppliers that I checked.
Add a comment
Add your answer
Kent Rhodes will be eternally grateful.
Past 24 Hours: 28
Past 7 Days: 28
Past 30 Days: 28
All Time: 28
