Shop the Holiday Gift Guide
The Sony Xperia XA2 Ultra cell phone was released in 2018, offering a 6.0-inch HD display, a max of 64GB of storage, and a 23-megapixel main camera.
Power and system damaged
Hello dear,my phone cannot enter to android it shows fix sign and after that did not respond power off completely,I checked the charging port and the battery,it ok
2 Comments
I hope this helps.
Phone Won't Turn On
by Share
Hello dear,thank you for your answer , actually I think it is a hardware problem the phone now did not open even the battery sign ,and the problem is ic power and I don't know which one on the mainboard ,and how I can change it .
by Share
Add a comment
1 Answer
Chosen Solution
@mohamedrad56224 if the "fix sign" was a warning triangle with a wrench or phone icon on it then this is usually caused by a failed boot partition or the OS being corrupted. That should not have turned your phone off or prevent it from turning on, but you do have to check for a software issue first.
You would need to download the Sony Xperia Companion software and then choose the Software Repair option. Follow the instructions to connect your phone. To force your phone into flash mode, make you are holding down the Volume Down button when plugging the phone in. If it disconnects or goes off completely while the software repair is going on, then you have a hardware problem.
Let us know what you find out.
Score 1
Add a comment
Add your answer
Mohamed Radwan will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 38
Past 30 Days: 38
All Time: 38
