Shop the Holiday Gift Guide
An all-rounder: coffee, espresso, cappuccino, latte macchiato, tea water, hot milk. Simple operation with touchscreen.
Simiens eq6 not starting
Machine ain’t working
Add a comment
1 Answer
Most Helpful Answer
I asked FixBot (Ai) your question with its answer in italics. Beware of Ai mistakes.
FixBot's answer
Does the display light up or make any clicking sounds when you press the power button, or is it completely unresponsive with no lights at all?
If the machine attempts to start (such as clicking, flashing lights, or trying to move the internal mechanisms) and then shuts down, it is often caused by:
  • A tripped safety mechanism or short circuit: Moisture inside the machine (often from a leak around the ceramic valve, heater, or flow meter) can cause a short circuit or trip your home's breaker.
  • Blocked mechanisms: A jammed brew group or ceramic valve can prevent the machine from completing its startup cycle.
  • Power supply or control board issues: A faulty main control board or blown internal fuse can prevent power from reaching the system.
Let me know what you observe when you try turning it on so we can narrow down the issue!
Score 1
Add a comment
Add your answer
Besmir Bacaj will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 25
All Time: 25
