Repair information for log splitters, also known as wood splitters.
Starting problem with log splitter
TroubleshootIng a failure to start for PowerHorse log splitter
3 Comments:
@dave83837 what model is your log splitter and what engine does it have (if you know)? Exactly what does your engine do when you try to start it?
by
@dave83837 To add on, we are not mind readers, and we certainly are not in your cameras. We need the exact information, excluding anything private, such as the Serial number.
by
Is your log splitter gas or electric?
by
Add a comment
1 Answer
What have you checked so far? Does the engine turn over when you pull the starter cord, or is it completely unresponsive?
Start with the basics: check the fuel level, make sure the engine switch is ON, and confirm the choke is set correctly for a cold start. Also check whether the spark plug wire is connected securely.
Add a comment
Add your answer
Dave will be eternally grateful.
Past 24 Hours: 9
Past 7 Days: 22
Past 30 Days: 22
All Time: 22
