Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
My MacBook doesn't cool properly
My macbook pro isn't cooling properly anymore and also it is making an awful lot of noise, my dad says it's because there is dust inside it. I don't dare to open it up because I'm scared that I won't be able to put it back together. my question is: Is it safe to open the back of my computer to remove possible dust from the fan?
I need help.
Score -1
Add a comment
1 Answer
Chosen Solution
Hello Douwe,
Don't be scared of opening up your computer. As long as you have the right tools, you should have no problem cleaning up any dust inside the computer. Here is a guide on how remove the fan, if that is the route you should choose.
It is also likely that the thermal paste should be reapplied. After a while, the thermal paste on the processors can go sour, causing symptoms just like you described. This guide will show you how to get the heat sinks off.
MacBook Pro 13" Unibody Mid 2010 Fan Image
Guide
MacBook Pro 13" Unibody Mid 2010 Fan Replacement
Difficulty:
Moderate
10 - 25 minutes
MacBook Pro 13" Unibody Mid 2010 Heat Sink Image
Guide
MacBook Pro 13" Unibody Mid 2010 Heat Sink Replacement
Difficulty:
Difficult
1 - 2 hours
Score 2
Add a comment
Add your answer
Douwe Vanneste will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 1,100
