Up to 20% off select tools
Repair guides, disassembly, and troubleshooting information for the Nintendo Switch 2's Joy-Con 2 controllers.
ZL Button Spring not working
I am trying to reassemble the left Joycon 2, and when I want to attach the ZL button, it feels like the spring is not doing its work. The ZL button is really steady and almost rubbing the button, so with a little touch it will press it.
Update (09/28/26)
Hello,
I was changing the covers. At the end I found the issue. The flex was not seating well on the support. From the top it looked like it was in the support, but I saw it sideways and it was not. This is why the ZL button was almost touching the button.
Thank you for reaching out!
2 Comments
Hi!
Glad that you figured it out :)! Have a great day!
by Share
Thank you! I was about to just accept I busted my controller until I found this.
by Share
Add a comment
1 Answer
Most Helpful Answer
Hi!
Please follow this to step 13: Joy-Con 2 (Left) Joystick Replacement
Could you show us how the spring look like?
What is the reason you opened it? Is another shell used or is this a cover that you have put on?
I know that some shells do not fit completely and could cause this as well.
Thanks!
Score 1
Add a comment
Add your answer
David Sandoval Galiana will be eternally grateful.
Past 24 Hours: 8
Past 7 Days: 34
Past 30 Days: 118
All Time: 199
