Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
549 Questions View all
Display too bright, even with brightness set to minimum
My iMac display is too bright even with "minimal" brightness (set with F1). If I choose maximum bright the brightness could burn anything that gets close to the display. My wife has another iMac and that does not happen in her mac.
What part should I change? Thanks in advance.
Score -1
Add a comment
1 Answer
Chosen Solution
You display is lightened by two backlights (fluorescent lamps) located at the top and the base of the screen. The backlights are driven by an inverter board who receive the electrical power from the logic board. I'm not a iMac specialist and maybe someone here could post the right answer but I think that the inverter board might send too much power to the backlights resulting in an over lightning issue. IMO the logic board or the inverter board is the culprit. You should bring the iMac to an Apple Store and ask a genius to look at it,
Score 2
Add a comment
Add your answer
Alfonso Mateos will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 10
All Time: 974
