How do I change my screen
How do I change my computer screen
Add a comment
1 Answer
Most Helpful Answer
Hi @harvelgordon
Here's the maintenance and service guide for the laptop.
Go to p.56 (64 of 92 pdf) in the manual to view the procedure to remove and disassemble the display assembly so that the LCD panel can be replaced.
There are 5 LCD panels that can be used in the model. Go to p.20-p.21 (28-29 of 92 pdf) in the manual Item #3 to find the HP part numbers for the LCD panels.
Search online using the applicable part number only for the panel in your laptop to find suppliers that suit you best. Usually the part number can be found somewhere on the back of the LCD panel, if you wish to verify that it is the one you want before ordering.
Score 1
Add a comment
Add your answer
Harvel Gordon will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 5
Past 30 Days: 23
All Time: 23
