CDMA version of the fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. 16 or 32 GB / Model A1349 / CDMA compatibility.
422 Questions View all
CDMA iPhone 4 bad reception; not antenna/motherboard
I have taken my Verizon iPhone 4 apart several times, but after my last conversion I have had bad service. I replaced the antenna/speaker module with no luck. Naturally, I figured that the problem lies with the motherboard, so I placed a fully working motherboard into the phone, but still no success. Also If I place the original motherboard into another phone it works fine. Is there something wrong with the frame of my phone that is making it have bad reception?
Comments:
Did anyone figure out this problem? Just ran into it myself with a formally working iphone 4 cdma...
by
Add a comment
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
Browse Our Store
Most Helpful Answer
You might want to clean all of the contacts with isopropyl to get any oils off of them. I replaced an iPhone 4's antenna and t had the same issue that you are describing here. Turns out that just a little bit of oil from your fingers can dramatically decrease and even cut off the signal. To prevent this, I always use latex gloves while working on electronics. You skald just take a small drop of isopropyl or another light degreaser and gently scrub each of the contacts with a soft brush. It fixed my problem. You might also have to clean the contacts on the logic board.
hope this Helps
Score 2
Comments:
what could i use the alcohol to clean? from experimenting with mix and matching parts, the only thing that is consistent each time with the phone is the metal frame, the screen, the camera and button connectors, the dock connector and that small connector at the top of the phone that you put the shield over. I'm convinced that it isnt the motherboard or antenna because if i stick both of those into another phone they work fine together.
by
Could someone point out to me where the actual "contacts" are? I've had bad reception on WiFi and Bluetooth since someone repaired my phone but I can't figure out where I'm supposed to clean.
by
Add a comment
Hello,
I totally agree with Owen. You should clean all the connections with Isopropyl at least 91% to get any oils off of them. Also I would examine the connectors under a microscope to make sure none of the connectors are damage, you can't see micro fracture with out a microscope.
Pressing to hard and taking your phone apart several times can damage these over time. If you have damaged them a little bit of micro soldering may be need to fully restore the connection.
Hope this helps!
Add a comment
Add your answer
Rindikulous will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,554
