Apple's smallest iPhone 14 was released on September 9th and comes with a 6.1" OLED display, an advanced dual 12 MP camera system, and a front camera with autofocus. Successor to the iPhone 13.
How to fix this
See image content:
3 Comments:
@eliassalomon What are you trying to fix? You gave us the picture, but you didn't give any context. What is it that you are trying to fix?
by
@user5136121 the metal piece that anchors the motherboard is torn off, you can see the solder pads where the piece should be
by
Add a comment
1 Answer
this happened to me as well😂if it's simply torn off then id say it's fine, you can either solder it back on or just cover the area with tape. The metal piece is likely there to just hold the motherboard in place and serve no actual function. Of course, I'm not certain whether it'll lead to more issues since I soldered mine back on, but for now if it works when you put everything back on and the phone doesn't restart every 3 minutes(which means it detected something missing), you're all fine.
Add a comment
Add your answer
Elias Salomon will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 12
All Time: 53
