Currently lost of power
No power I don't know what happen it directly lost power since my last used
1 Comment:
@jundeewong Do you mean that the toaster itself doesn't have power, or does your whole house not have power? If your toaster does not have any power, then I suggest opening it up and changing out the PSU or power cord. If your whole house does not have power, then I would suggest that you either wait for the electricians to bring the grid back up, or change the fuses if the fuses for your home has blown.
by
Add a comment
1 Answer
If you didn't check you outlet ckt breaker, then my assumption would be, u can't fix it if I told you what the problem was.
However, assuming the breaker is tripped, then the issue might be a bad middle door switch or a worn mechanism.
Add a comment
Add your answer
Jun Dee Wong will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 18
All Time: 73
