Repair information and guides for the fifth generation of iPhone. Model: A1387
2201 Questions View all
What is this part? Any chance it's not crucial?
In the disassembly process of Iphone 4s a small square part fell off the motherboard (see picture). What is this part? Any chance it's not necessary? If not, is there any way to fix it?
Thanks a lot!
Score -1
1 Comment
Could somebody please give me an advice if I should try to fix it or just sell for parts?
by
Add a comment
1 Answer
Most Helpful Answer
Yes it is crucial, but it is repairable. It needs to be re-soldered into position on its contacts, but the orientation is also important, it must go back on in the same way it was before it came off. Look at the other similar part (just to the left in the picture) and see if it has any markings on it that orient the part. It may also be possible to see the orientation from looking at the part that fell off, look at the bottom contacts and see if there is any way the solder break(s) look like they fit the contact points on the motherboard contacts. You may be able to tell just by trying to re-fit the part onto it's contacts and see if there's only one way it fits into the broken solder points properly.
Good luck, and be careful about static, use anti-static measures whenever you work with electronic parts.
Score 1
Add a comment
Add your answer
zavidovych will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 10
All Time: 829
