Freestanding Ice Makers
Because it throws the error E6 ice machine
Hello, good morning, how are you? I wanted to ask about the ice machine that throws an error E6
Update (08/17/26)
Here is information @oldturkey03
Mise à jour (08/17/26)
aquí esta la información
@oldturkey03
3 Comments:
@jobelchinc94719 what's the make and model of your ice maker? There should be a metal shield on the back of the icemaker that list all the pertinent information of the machine. Post a picture of that with your question.
by
Aqui la información
by
[image|5409478]aquí esta la información
by
Add a comment
1 Answer
From what I can find on this R32 commercial ice machine (Model ICEBS01) an E6 error code points to a temperature sensor/thermistor malfunction on the control board circuit. The micro-controller triggers E6 when the circuit detects an open circuit (infinite resistance) or short circuit (0 ohms) from one of the probe lines.
Primary Causes & Diagnostics
Evaporator/Ice Thickness Sensor Fault: The probe clamped to the evaporator line or grid has shorted out or lost continuity due to thermal stress or moisture ingress.
Condenser Sensor Open/Short: The sensor monitoring coil temperature is failing, preventing the board from managing heat dissipation safely.
Wiring / Plug Corrosion: Damp conditions inside the cabinet causing corrosion or a loose connection at the PCB terminal block.
Control Board Processing Error: Corrupted logic readings or a damaged analog-to-digital converter pin on the main PCB.
Step-by-Step Isolation Process
Power Hard Reset
Disconnect the main plug, wait 5 minutes for the onboard capacitors to discharge, and power back on to verify if it's a transient glitch.
Inspect Harness Connections
Access the main PCB behind the service panel.
Locate the multi-pin sensor connectors (typically labeled NTC1, NTC2, TEMP, or T_EVAP).
Unplug and check for moisture, green oxidation, or bent pins.
Multimeter Resistance Check (Ohm Testing)
Disconnect the thermistor leads from the board.
Set your multimeter to ohms/resistance and measure across the sensor leads.
Normal reading: Typically around 5 K Ohms to 10K ohms at room temperature (77°F/ 25°F).
Faulty reading: 0 ohms (short circuit) or OL (open wire) indicates a dead sensor that needs replacement.
Replace Sensor or PCB
If thermistor resistance is within spec, the fault lies in the main control board's input circuit, requiring a PCB swap.
Add a comment
Add your answer
Jobel Chinchilla (Jobel) will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 11
Past 30 Days: 58
All Time: 175
