The third revision of the classic Xbox Wireless Controller was released in November 2020, bundled with the Xbox Series X and Series S. This controller is backwards compatible with previous Xbox One consoles, and PCs.
Potentiometer of joystick replacement problem
Hello,
I replaced the one potentiometer of joystick from a Xbox Series X controller but when trying it I was not able to calibrate it. Changed again and same thing. Does the potentiometer has to have an initial resistance value so I am able to calibrated? Maybe the resistance is very high/low to be able to
3 Comments
Did you just change the potentiometer only or the whole joystick assembly? Did you try to cslibrate on a PC or an Xbox?
by
I changed only the potentiometer 2 times with no success. The the whole joystick worked. I calibrated it on a emulator in PC because I don't have an actual working Xbox Series X
by
Okay, glad that replacing the joystick worked. Should be OK now! Calibrating on the PC should do it! Have a nice day :)!
by
Add a comment
1 Answer
Chosen Solution
Hi!
Whenever the potentiometer won't fix it, it's advised to replace the joystick assembly completely.
You can follow this guide for that: Xbox Series X/S Wireless Controller Joystick Replacement
After this is done, you can try to calibrate them again.
Please let us know how it goes!
Score 2
4 Comments:
Hi,
Thank you very much. I discovered that I was using the same potentiometers I use for PS5 controller and the resistance value is different (PS5 2k3 ohm and Xbox 10k ohm) so that was the issue why I could not calibrate it
by
Ah that explains it!! It’s correct that they are different. Glad that you found out :)! Have a great day!
by
I replaced all my ps4 controller sticks with hall sensor ones. Never had a problem since.
by
Yes that works :)! But this is regarding a Xbox controller. I heard that sometimes it can interfere here with the magnets.
by
Add a comment
Add your answer
sascha bauló martínez will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 48
All Time: 178
