Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
Fan Spin - No Boot - No Display
2012 A1278 Model on the bench.
It turns on, fan spins, but that is it nothing else happens.The sleep light is on.
I have tried, removing RAM, Swapping RAM, Without the KB connected, Without a display, different HDD / SSD, Different working HDD cable, Reset SMC, PRAM etc..... Board looks clean, no water damage evident. Owner siad it just wouldn't start anymore. It does charge the battery though.
Add a comment
1 Answer
Most Helpful Answer
What's good Livfe? This sounds like the CPU might not be executing?
It could also be a corrupted Bios.
For the CPU:
Check:
  • PPBUS_G3H (~12.6V)
  • PP3V42_G3H
  • PP3V3_S5
  • PP5V_S5
  • PP3V3_S0 (after power-on)
  • CPU core voltage (VCORE)
If VCORE never appears, the CPU isn't being enabled.
Score 1
1 Comment:
Thanks, we will look into this and update with any findings :)
by
Add a comment
Add your answer
livfe will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 44
All Time: 44
