Samsung Galaxy A32 (SM-A325F) aka Samsung Galaxy A32 4G Released in 2021, it uses a Gorilla Glass 5 front glass and a Super AMOLED 1080 x 2400 pixel display.
Question Closed
1. Wi-Fi Issue: 2 Bluetooth Issue
"My Samsung Galaxy A32 has a Wi-Fi and Bluetooth issue. The phone cannot detect nearby Wi-Fi networks properly. It only detects a mobile hotspot when it is very close, and the signal disappears after about 2–3 feet. Bluetooth detects devices but fails to connect to them. I have already performed a factory reset, reset the network settings, and tested the phone in Safe Mode, but the problem still exists. The phone has been dropped several times, and the back housing was replaced during a previous repair. Please check the Wi-Fi/Bluetooth antenna, antenna contacts, and the Wi-Fi/Bluetooth IC."
Add a comment
1 Answer
As you are able to sense the AP when you are very close that tells us the signal is being detected but not at the needed strength for a bit of distance. That tells us the connection at the logic board where the antenna connects and onwards to the antenna its self is severed. This is also why the Bluetooth is likely failing as well
This will likely need some parts (Case shell) and/or soldering are you up to the task? If not you should seek out a good track to fix your phone.
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 20
