The Bajaj Discover is a motorcycle brand by Bajaj Auto. Currently there are four variants of Discover- Discover 100 DTS-Si,Discover 125 DTS-i,Discover 125ST and Discover 150 DTS-i.
Why long light not working
Patina long light not working why
Add a comment
1 Answer
Most Helpful Answer
Hi @nigusutegene
When you say "..long light..." do you mean the high beam headlight?
If you do, have you checked if the headlight bulb is OK. It is a twin filament bulb i.e. one filament is for the low beam and the other for the high beam. When the high beam is turned on, both filaments are lit.
If the headlight bulb is OK does the high beam indicator light in the instrument panel, turn on when you operate the headlight dimmer switch to turn on the high beam headlight?
If it does then if the headlight bulb is OK it could be a wiring problem between the headlight dimmer switch and the headlight.
If it doesn't turn on it could be a faulty headlight dimmer switch.
Here's the wiring diagram that may help if it's a wiring problem.
(click on image)
Score 1
Add a comment
Add your answer
Nigusu Tegene will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 8
All Time: 41
