Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
Question Closed
battery does not work! it wont charge!
3gs battery replacement
i bought a new battery and when i plugged it in the charge, the new battery will not charge. i changed it back and my old battery works fine.
do i have to set up the battery in a certain way, or what?
Add a comment
1 Answer
What exactly is the kind of your old and new batteries? and if your old batterie works fine, why get a new one? Look first if both are compatible. Watch also how you deposit your new batterie inside to see if it is well connected, as a batterie always have a positive and negative, phone batterie always at the same place.
1 Comment:
the kind? it was a 3gs battery, like the old one..
my old battery did not work fine, it would last for a half hour, and then die at 90%. but the fact that the old battery recharges is a sign that tells that i have not done anything wrong when i was installing the new battery! it means that can reassemble my iphone perfectly without damage.
i do not understand ? compatible? i bought a 3gs battery for my 3gs iphone; so how could it not be compatible?
the new battery works, even though it does not recharge. it just goes down from 20% i think it was about 10% when i gave up. but it worked perfectly fine.
by
Add a comment
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 2
All Time: 286
