Up to 20% off select tools
The tenth generation Ford F-Series is a line of pickup trucks that was produced by Ford Motor Company, it was sold from the 1997 to the 2004 model years.
Check engine light on
PO171 PO174 error codes
Add a comment
1 Answer
Most Helpful Answer
Hi @markschoepke
The codes indicate a fuel too lean in Banks 1 & 2 problem.
This is usually either an airflow problem (too much air) or too little fuel getting to the engine.
Here's a video that shows how to check if the MAF (mass air flow) sensor is OK or not.
If it's a fuel problem it could be a clogged fuel filter or a fuel pump problem - low pressure
Hopefully a start to find out what's wrong.
Score 1
Add a comment
Add your answer
mark schoepke will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 11
All Time: 88
