Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
iPhone 4 only works on charger
i have an iPhone 4 which appears to only work on the charger. as soon as it has been removed from the charger it turns off. and you can't do a thing with it unless on the charger. i was just wondering what the problem is, how to fix it, and what part/s i need.
i hope you can help!
Score 1
1 Comment
Ok thanks, i will see how i go!
by
Add a comment
Most Helpful Answer
I have the same problem.....apparently is a bad battery or bad dock connector. I haven't had the time to try and fix it. So what I suggest is take your iPhone apart and reassemble it, to make sure everything is as it should be!
Score 1
1 Comment:
IF that does not work :) start with the easy thing and replace the battery. Should it not charge, replace the dock connector. Follow these guides iPhone 4
by
Add a comment
Try replacing the battery. It's a relatively cheap and easy fix and seemed to help my iphone 4. Good luck and hope it helps!
Add a comment
Add your answer
Brice will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 4,967
