PS4 Controller model CUH-ZCT1. Released in November 2013 by Sony Computer Entertainment, this six-axis, 3.7 V lithium ion battery controller is uncomplicated to repair. (NOTE: Teardown guide is NOT for this model)
Why ps4 controller does turn on on
My PS4 and another controller work perfectly fine, so the issue is only with one specific DualShock 4 controller.
Problem details:
When I connect the controller with USB, the orange charging light appears briefly and then turns off. Pressing the PS button does nothing. I charged it for over 24 hours with no change. I already tried resetting the controller using the reset button on the back. The same USB cable and PS4 work correctly with another controller.
Because another controller works normally on the same PS4, I think the issue is inside this controller itself.
Does this sound more like:
a dead battery, faulty charging board/USB port, or motherboard failure?
2 Comments
When you have the charger on it, and press the PS button, nothing happens as well? Or does it work when plugged in? If yes, replace the battery. Otherwise you need to check the membrane. Is it a Power A controller or genuine Dualshock 4? Thank you.
by
@dan0 when I plugged in nothing happens and it is dualshock 4
by
Add a comment
1 Answer
Chosen Solution
Hi!
Thank you for your comment.
First: replace the battery and see if that solves it.
Guide: DualShock 4 (CUH-ZCT1U) Battery Replacement
If not, you most likely need to check the membrane. But first of all, replace the battery and see what happens!
Guide for the membrane circuit: DualShock 4 (CUH-ZCT1U) Button Circuit Membrane Replacement
Thanks!
DualShock 4 Battery Image
Guide
Difficulty:
Moderate
15 - 30 minutes
DualShock 4 Button Circuit Membrane Image
Guide
Difficulty:
Moderate
1 - 2 hours
Score 1
Add a comment
Add your answer
ASIF Iqbal will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 37
All Time: 104
