Model A1369, 1.6, 1.7, or 1.8 GHz Processor, 64, 128 or 256GB Flash Storage
328 Questions View all
Question Closed
No sound internal speakers, headphones and no light on magsafe tip...
Hi, my friend spilled liquid on his macbook air, and i cleaned it all out with 91% iso al. once put together everything works except that there is no sound from internal speakers, or headphones and there is no light on tip of magsafe charger.
under audio on hardware tab it says
Intel High Definition Audio:
Audio ID: 91
there was corrosion on logic board and i/o board. but do you think a new i/o board and cable would fix the sound issue and charger? would a faulty i/o board disable all sound from mac or would still one speaker work because the left speaker is connected directly to the logic board?
any suggestions would be greatly appreciated in helping me debunk this for my friend !
thanks in advance! ill leave it to the PROs. :)
Add a comment
1 Answer
Chosen Solution
Yes a defunct audio board kills all sound. Sounds like you need a new Audio Board, and DC-in Board.
If this Answer is helpful please remember to return and mark it Accepted.
2 Comments:
thanks!
by new audio board and dc-in board. are you referring to the i/o board which is both? or is the audio board a component on the logic board?
thanks again!!
by
Yep that's the one.
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 1,136
