Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
Question Closed
Why is my screen really dim?
I have an iphone that my dad had for 2 years, i bought it at the beginning of 2012 and a month or two ago now, it has started breaking. First the volume button came off, but thats not a problem. Then one day the screen was just really dim and everything functioned normally except for the screen. I had synced it up to my parent's computer to move some ringtones across. the screen is fine to look at underneath some sort of light like a lamp or the sun lol but i need help i havent dropped it heavily that often
1 Comment
Unknown model of phone - please identify your phone.
Any drops or smashes can damage your phone and it's not
possible to tell from the words how badly it may be damaged.
by
Add a comment
1 Answer
Chosen Solution
Harry, that does sound like your backlight. There are a few parts that can cause this. First, the LCD. It sort of functions as the light bulb in your house. Second the 6R8 coil which works like the switch and third the IC 109B. Of course this is in simplistic terms, but it should give you an idea. I would start by replacing the LCD, and then work backwards. The LCD is the easier one to change since the coil is soldered onto the logic board as well as the IC. The coil is easier to change than the IC:). Anyhow, for the LCD check this guide. For the coil check on here. Hope this helps, good luck.
Score 1
2 Comments:
thanks dude am going to take my phone apart at the weekend thanks for the help
by
Thank you for accepting my answer. Best of luck to you and let us know how it is going.
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 6,871
