A compact digital camera released in February 2009. Features a 2.5" display, 10 MP digital sensor, 3X optical image stabilized zoom with face detection. Available in silver, dark gray, orange, green, pink, and blue.
Canon Lens Will Not Retract
For context, my friend gave me this ixus 95 (Sd1200) camera to keep, and it said to replace the battery so i charged it up, and it worked fine. When i tried to use the autofocus function, since it was still blurry, it wouldn't work, so i kept trying and eventually the camera effectively crashed, leaving the lens extended, now every time i power it on, it does a couple clicking noises then hands me a lens error. I was looking at the lens and the gap between the lens itself and the casing it a little uneven. I want to know if there is anyway to fix it. (for added context, my friend had it in their room for a while and its been a while since they tried turning it on.
Add a comment
1 Answer
@propanepropane sadly enough this is a common error with any digital camera that utilizes a telescopic lens. Look through the suggestion on here Fix#4 might work for you.
if it can't be corrected you will have to repair/replace the lens. For that use this guide Canon PowerShot SD1200 IS Lens Assembly Replacement
Add a comment
Add your answer
Propane (Propane) will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 32
All Time: 103
