Air conditioner not.working
After replacing tipm my air conditioner is no longer working. Replace relay, its fully.charged but.still doesnt work
If the A/C stopped working right after replacing the TIPM, the issue is likely related to power, programming, or communication rather than the refrigerant charge itself.
A few things to check:
Since you already replaced the relay and confirmed the system is charged, I would focus on electrical diagnosis next. A multimeter or scan tool will help much more than replacing more parts randomly.
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 37
All Time: 37
This question was migrated from https://meta.ifixit.com/Answers.
by iRobot
Hi @kathy21141
As you mentioned replacing the tipm, I assume that the air con is in a motor vehicle.
If this is correct, what is the make, model and year of the vehicle?
Moderator.
by jayeff
@jayeff 2019 dodge grand caravan
by Kathy
@kathy21141
Does the blower motor work when you turn on the air con?
Can you hear the compressor clutch operate when you turn on the air con - with the engine idling there should be a clunk sound as an electric clutch engages the compressor pulley so that the serpentine belt turns the compressor?
by jayeff
