15% Off Selected iFixit Tools — Limited Time
Repair and disassembly information for the Nokia 3. The Nokia 3 is an Android smartphone released in June 2017. Identified by model numbers TA-1032, TA-1020, TA-1028, and TA-1038.
No power won't turn on or charge
No power to phone from charger won't turn on
1 Comment:
Have you tried connecting it to a computer to see if there's any sound that the pc recognized it was plugged in the USB port?
by
Add a comment
1 Answer
@michaelcha69868 start at the basics and let us know what you find out. Let us know the exact model number for your Nokia 3.
First check your charger. Make sure it has proper output. Then check your charging cable. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a USB ammeter and see if your phone draws any amperage from the charger. If it does not it is possible that this is a charging port issue or a bad battery.
Add a comment
Add your answer
Michael Charallam will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 23
All Time: 42
