Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544 Questions View all
How to Install SSD
I want to install a SSD into my MacBook Pro 17. I bought a Mercury Electra 3G SSD. How do I install it into my MacBook Pro? It didn't come with directions, although they told me it would work.
Score 3
Add a comment
Chosen Solution
I just installed a second hard drive in the place of the optical drive in my MacBook the other day! It's pretty nice having the extra capacity.
Even if you just replace your current hard drive with your SSD, you'll see a significant speedup.
Here are the relevant guides:
Replacing the current hard drive:
MacBook Pro 17" Unibody Hard Drive Replacement
Removing the optical drive:
MacBook Pro 17" Unibody Optical Drive Replacement
Go to the last page of this guide on replacing the optical drive (it's for my machine, but the last page would help for installing the second drive)
Installing MacBook Core 2 Duo Dual Hard Drive
And finally, the part that iFixit sells for the second hard drive:
Unibody Laptop Dual Drive
Good luck and enjoy your SSD!
Unibody Laptop Dual Drive Image
Product
$24.99
MacBook Pro 17" Unibody Hard Drive Image
Guide
Difficulty:
Moderate
15 - 30 minutes
MacBook Pro 17" Unibody Optical Drive Image
Guide
Difficulty:
Moderate
1 - 2 hours
MacBook Core 2 Duo Dual Hard Drive Image
Guide
Difficulty:
Moderate
1 - 2 hours
Score 1
Add a comment
Most Helpful Answer
You either have to: 1.) replace your current HDD with the SSD or 2.) remove the SuperDrive CD burner and replace with your current HDD and put the SSD in the original place that the HDD was in. The latter is the most popular because you can still use the SuperDrive via USB by purchasing external case for the SuperDrive and you just plug and play with the USB, therefore having a HDD and SSD. Also, with the latter, you must purchase an OptiBay expansion kit to be able to place the HDD into the SuperDrive bay.
Score 1
Add a comment
Add your answer
dconkright will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 9
All Time: 25,587
