A collection of guides and support to help with washer repair.
Service code Washing machine Indesit Wib111
Hi, may I ask if anyone knows what this service/error code means?
After a power outage, I wanted to continue the washing cycle. The washing machine would not start. I reset the program by holding the START button for a long time. The washing machine lit up all the LEDs. Then they turned off and nothing happened.
Exactly 20 minutes later, the pump starts running and the LOCK LED begins flashing rapidly, while the RAPID WASH LED flashes a little more slowly. After 5 minutes, the pump stops, but the LED combination keeps flashing in the same way.
There should be two hidden diagnostic LEDs on the inside of the control panel. They are not flashing.
The door lock is working — verified.
The motor works.
The heating element works.
The pressure switch works.
The pump works.
I measured continuity with resistance at the output of the temperature sensor.
The tacho generates voltage according to motor speed when the motor is turning.
The relays on the control board are functional.
Everything was tested outside the washing machine wiring.
The electrolytic capacitors have been replaced.
The triac controlling the door lock is fine and was replaced just in case.
What seems strange, however, is that the door lock engages almost immediately after the washing machine is plugged into the mains. This happens because the processor’s control pin sends a signal to the base of the transistor that triggers the triac.The door lock unlocks only if I unplug the washing machine from the mains.
thank you
Add a comment
1 Answer
Hi @petr3946
You said that you tried to reset the washer by holding the Start button operated for a long time is this correct?
The usual way to reset a washer after a power failure is to disconnect the power from the machine and then press and hold the On/Off button for about 30 seconds and then release it and then reconnect the power to the machine and check if it now works OK.
Give that a try and see if it works for your model.
1 Comment:
Hi Jayeff, thank you for your help and yes, it it correct. I reseted washer by holding the Start button operated for aprox.5-7s.
I have tried your advice as you described and it does not work. After 30s i released the button. Then i reconnected the power to the machine. The lock locked by itself, then i pressed On/OFF, then Start. Valve opened for a 2seconds, then closed. 20min past, pump started, error code same.
Version of my model is 46464700100.
thank you
by
Add a comment
Add your answer
Petr will be eternally grateful.
Past 24 Hours: 7
Past 7 Days: 25
Past 30 Days: 25
All Time: 25
