Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
212 Questions View all
How can I tell if my new LCD panel is good?
Hi everyone
I bought a used 20" Intel iMac that supposedly only needed a hard drive and a new LCD panel in order to work. The hard drive was easily installed. I ordered a replacement panel off eBay and installed it, but I'm seeing a grey screen with lots of tiny black rectangles on it. I figured that maybe there's a problem with the video card, so I scrounged up a Mini-DVI to DVI adapter, and connected an external monitor. However, nothing ever displays on that external monitor. If there is truly a problem with the video card (the logic board?), I'm going to stop buying parts and sell the carcass....
Anyway, how can I tell if the replacement LCD is good? Does the weird pattern I'm seeing on the display indicate a problem with the panel or with the video card? And shouldnt the iMac automatically output to the external display when I connect it via the adapter?
Thanks!
Score -1
Add a comment
1 Answer
Chosen Solution
No external video is an indicator of VGC problems, the screen artifacts you describe also point to the VGC. With a questionable or non working VGC you can't make any firm conclusions about the LCD.
If you got the Original Install Disks there's a hardware test on it.
If this Answer is helpful please remember to return and mark it Accepted.
Score 2
Add a comment
Add your answer
Craig Wyzik will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 383
