Why does mine keep giving a boot error
Its something with the disk drive but it says something about master and slave slots
Update (06/16/26)
Turns out it was a dead cmos battery
@caseyteska36918 your computer does not "see" the boot disk. Either you have a bad HDD/SSD or corrupted OS boot files. Enter your computer's BIOS on startup and check the boot sequence to make sure it is not configured to boot from a Network. Make sure your hard disk is listed in the boot sequence. Make your hard disk the first device in your boot order. If is is bing seen etc. then you could try to repair the OS or reinstall it. Also reset your BIOS to factory default settings.
If your Boot drive is not visible it will have failed. In that case you would need to replace it and reinstall an OS.
Prob a bad hdd because the computer tower has the original hdd and it's from 2008 so could be
@caseyteska36918 yeah, that would be my first guess be as well.
Yea it's probably a bad hard-drive but it's not clicking like how bad ones do so might be corrupted
@caseyteska36918 definitely unexpected :-) but glad you got it figured out and fixed!
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 17
All Time: 126
5 Comments
What is the actual error message? Does the computer keep restarting after the error message?
by honakrisi
It also doesn't read the disk drive
by Casey Teska
Are you able to enter the bios by pressing DEL button upon startup and look at your boot priority? You can disble the disk drive which could interfere with your boot sequence
by honakrisi
I was able to and doesn't read the hdd it reads disk sorry for inconvenience
by Casey Teska
Try holding down the shift key when turning on your computer and see if it takes you to the advanced boot manager.
by honakrisi
