The HP Wired Desktop 320M Mouse is a reliable, no-frills wired mouse, released as part of HP's desktop accessory lineup. Designed for everyday use, it features a simple, ergonomic design with a 1000 DPI optical sensor for precise tracking. Its USB connection ensures a stable, lag-free experience, making it a great choice for both work and home use. The HP Wired Desktop 320M is durable, comfortable, and built for efficiency, offering a straightforward solution for users seeking reliable, budget-friendly peripherals.
Scroller is not working
Scroller is not working properly.How to fix it?
Score 1
Add a comment
I do not know how long you have had this, but if it has been a few years and the scroll wheel is smooth, it is just because of wear and tear, and the easiest way is to buy a new mouse.
Add a comment
I had a similar problem with a different brand of mouse. The axle on the scroll wheel had broken due to excessive stress, so I took the thing apart and used some super glue to stick it back on. Surprisingly enough, it's still holding up, so you might want to try this before you go and buy a new mouse. You have to be careful and make sure the axle is aligned to the spot it broke off from and that it's not crooked, or otherwise the wheel could "wobble".
Add a comment
It's almost always a cracked wheel or the mechanical encoder is broken. Buy a new mouse, they're $10-15 a pop for a basic no frills mouse like the Logitech M100 and many, many private label ones which are often under $10. A mouse is a mouse, as long as it's not a Magic Mouse it will work and is probably ergonomic enough.
I have a nice mechanical keyboard, and yet I still buy $8-20 throwaway mice. I throw more money away on eBay and yard sales then I will spend on a basic mouse (or a spare I got on clearance). if you want to try and see what you can do, take it apart and see but most of the time the mouse is a lost cause. You can get them for $8 at Walmart: https://www.walmart.com/ip/onn-3-Buttons...
2 Comments:
Like I said, in my case all it took was superglue, so I'd say there's no sense in not trying to fix it at the very least.
by
@fixerofstuff Mice are rarely fixable in my experience, they're almost always something that needs soldering to repair. The 320M is a OEM mouse (I have a Elite Mini 805 G8 which whipped with the 320M/320K and the original box with low SSD hours, I hate that style so I just installed the PC and sidelined the keyboard and mouse). If I needed the mouse, I can buy those all day on eBay in pairs of 3-5 and if you buy a modern Elite Mini/EliteDesk, HP uses the 320K as the default board (the good 125K is optional) and it's built accordingly vs the 125K.
by
Add a comment
Add your answer
Vishal Raj will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 59
All Time: 377
