Repair and disassembly information for Rakuten Kobo’s Clara BW (black and white) eReader, released in April 2024. Identified by model numbers N365, N365B, or P365.
The on/off button
the on/off button broke and now I need to turn the device on/off using a coin. Is there a replacement button available?
Score 1
Add a comment
1 Answer
Most Helpful Answer
Try making one out of hot glue, a bit of plastic or rubber, or 3D printing. To make a button out of glue or plastic, remove the logic board (you won't have to remove the battery as it sits in a cutout). Then trim the new button or add glue as needed until the logic board fits back in neatly.
My hot glue button looks like this:
It sits quite stiff in the button hole and I can use it by pressing it firmly with my thumbnail. Incorporating plastic from a recycled container would probably make the button less stiff if you prefer.
Score 1
Add a comment
Add your answer
Dieter Haes will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 29
All Time: 206
