Kobo Clara HD Repairs
    1. Kobo Clara HD Repairs, Before starting: step 1, image 1 of 1
      • To power off your device, hold down the power button until the "Powered off" screen appears as shown.
      Ask FixBot
    2. Kobo Clara HD Repairs, Back cover: step 2, image 1 of 3 Kobo Clara HD Repairs, Back cover: step 2, image 2 of 3 Kobo Clara HD Repairs, Back cover: step 2, image 3 of 3
      • Stick a plastic spudger into the gap between the front bezel and the back cover.
      • The back cover is held on by small plastic notches.
      • Slide the spudger along the seam to release the back cover.
      • Pry all the way around until the back cover pops free.
      Ask FixBot
    3. Kobo Clara HD Repairs, Battery: step 3, image 1 of 3 Kobo Clara HD Repairs, Battery: step 3, image 2 of 3 Kobo Clara HD Repairs, Battery: step 3, image 3 of 3
      • Gently pry up the white battery connector to pop it out of its bracket.
      Ask FixBot
    4. Kobo Clara HD Repairs, Screen connectors: step 4, image 1 of 3 Kobo Clara HD Repairs, Screen connectors: step 4, image 2 of 3 Kobo Clara HD Repairs, Screen connectors: step 4, image 3 of 3
      • Flip up the black tabs on the three ZIF connectors to release the ribbon cables.
      • The smallest connector, under the big cable, has the black locking tab facing towards the cable.
      • Slide the ribbon cables out of the ZIF sockets.
      Ask FixBot
    5. Kobo Clara HD Repairs, Battery: step 5, image 1 of 2 Kobo Clara HD Repairs, Battery: step 5, image 2 of 2
      • The battery is stuck down with strong double-sided tape and secured by a bracket moulded into the back cover.
      Ask FixBot
    6. Kobo Clara HD Repairs, Storage: step 6, image 1 of 2 Kobo Clara HD Repairs, Storage: step 6, image 2 of 2
      • All the storage is on a microSD card hidden inside the device.
      • Swap it out at your own risk.
      Ask FixBot
    7. Kobo Clara HD Repairs, Logic board: step 7, image 1 of 2 Kobo Clara HD Repairs, Logic board: step 7, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the 4 screws securing the logic board.
      • Lift the logic board out from the top of the device.
      • There is a black sheet of plastic that sits under the logic board.
      Ask FixBot
    8. Kobo Clara HD Repairs: step 8, image 1 of 2 Kobo Clara HD Repairs: step 8, image 2 of 2
      • To reassemble your device, follow these steps in reverse order.
      • Pro tip: when closing the plastic housing, squeeze it shut close to the edges to avoid putting too much pressure on the display.
      Ask FixBot
Finish Line
4 other people completed this guide.
Sparky
1,827 Reputation
13 Guides authored
0 Guide Comments
Past 24 Hours: 14
Past 7 Days: 129
Past 30 Days: 591
All Time: 2,541
