The Saturn Relay was the first and only minivan from the Saturn brand of American automaker General Motors and was built alongside its sisters, the Buick Terraza, the Chevrolet Uplander, and the Pontiac Montana SV6.
Remove alternator from engine
I have alternator broke but can't find space to pull the alternator out
1 Comment
Alternator is loose but I can't get out frustrating
by
Add a comment
1 Answer
Most Helpful Answer
@donaldmart53225 here are the instructions for the Generator Removal from the workshop manual. If there is anything in the way etc. you want to go ahead and post some good pictures of your situation. That way we can see what you see and hopefully find a solution. Adding images to an existing question
Update (02/06/26)
@donaldmart53225 all the wires are loose and your removed all the bolts etc.? Where are you stuck? You normally are supposed to drop the engine. Take a look on here to see how to try and do it without dropping the engine, or on here where you drop the engine.What a PITA
Score 1
Add a comment
Add your answer
Donald Martin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 16
All Time: 172
