Repair information and guides for MacBook Pro models with 13" displays.
9745 Questions View all
Question Closed
after disassembling my mbp,bluetooth and camera stop working
after disassembling my mbp,bluetooth and camera stop working。i‘m from china,so,my english is poor,forgive me。hope you can understand what i say and answer my question,thank you~!
Add a comment
Which model of Macbook Pro do you have?
2 Comments:
Try to do a PRAM reset. Switch off your laptop. Then press power button and immediately hold option+command+p+r buttons together before the apple logo comes up. You will hear the chime sound. Keep holding the buttons and then release until you hear the second chime sound. It should reset the PRAM and hopefully will fix the bluetooth and camera issue.
by
Good course of action. I'd add, to gauge what Macbook Pro exactly is, that our user should go into "System Profiler" and provide the iFixit Community with the last three letters and numbers of the Serial Number.
Also, an SMC reset, different if the Macbook has or hasn't a removable battery, is in order.
by
Add a comment
I have had exactly the same issue. However this did not fix the issue. Do both of these components attach using the same connector? I suspect i might have damaged the connector in some way with a bodged attempt at refitting it.
How likely is this. The connector looks very fragile.
Chris
Add a comment
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 556
