Apple's mainstream 2020 iPhone was released October 23rd and comes with a 6.1" OLED display, a dual 12 MP camera system, and in five available colors. Successor to the iPhone 11.
iPhone 12 buttons replacement guide
Hi everyone
I replaced the buttons with new ones, there are no gaps, everything is fine, but I'm lost, I can't understand how long the screws are needed…
Everything is fine, but when I tighten the screw to the end, the button is not pressed, although everything is in place
Could you please tell me if I need to buy these screws separately? And are they sold on AliExpress? What length of screws for buttons do I need?
Score 1
Add a comment
1 Answer
Chosen Solution
Unfortunately, there aren't many guides out there for button replacements on iPhones. The closest I can come is to point you to the guides for the iPhone X; fortunately, Apple hasn't changed the basic design of the buttons throughout most of its various models, so the principles will be the same.
iPhone X Charging Pad / Volume Button Assembly Replacement - iFixit Repair Guide
You might compare your work to that for the iPhone X; on that one there are four different lengths of screws used so you might try comparing yours with those on the X and see if there's any correspondence there.
Have you done anything with the exterior buttons? Those could also affect whether the internal buttons are working or not. If you didn't remove or disturb them, then you're probably okay, but there is a guide to replacing those as well on the iPhone X. Again, this procedure will be identical to your phone, at least with respect to actually removing and replacing the buttons themselves, although the procedure of how you get to them will be different.
iPhone X Power and Audio Exterior Buttons Replacement - iFixit Repair Guide
I hope this helps; feel free if you have any questions I may be able to answer since I wrote those guides.
iPhone X Charging Pad / Volume Button Assembly Image
Guide
Difficulty:
Difficult
iPhone X Power and Audio Exterior Buttons Image
Guide
Difficulty:
Difficult
1 Comment:
@maksimsokurov said, "So the screws in the instructions are the same as those in the iPhone X?"
I'm sorry, but I do not know the answer to that for sure. I suspect they are similar, but I can't guarantee they are the same. Is there a chance you aren't sure the screws were put back in the same place they came from? As you can see, there are different lengths in different positions.
Извините, но я не могу с уверенностью ответить на этот вопрос. Подозреваю, что они похожи, но не могу гарантировать, что они одинаковые. Возможно, вы не уверены, что винты были вкручены обратно на те же места, откуда их выкрутили? Как видите, винты имеют разную длину в разных местах.
by
Add a comment
Add your answer
Максим Сокуров will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 40
All Time: 274
