Repair information for the sixth-generation Nissan Altima, covering model years 2019 to present.
How do I replace a thermostat?
Where is the thermostat located and how do I replace it?
Score 1
Add a comment
1 Answer
Most Helpful Answer
Hi @clinton38566
What is the engine size and which thermostat do you need to replace?
Reason for asking is the 2.5L engine has 2 thermostats whereas the 2.0L engine only has 1.
Score 2
3 Comments:
It's the 2.5L. I believe its the main engine thermostat, since its the one that works with the heater core. I currently don't have heat in the car and was advised that this is most likely the reason.
by
@clinton38566
The video in the blue link above shows a thermostat in the engine block being replaced at 3:26 minutes
by
@jayeff Thank you. I'll check it out.
by
Add a comment
Add your answer
Clinton will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 18
Past 30 Days: 78
All Time: 384
