iPhone 3GS wont charge
wont charge when plugged in says"charging is not supported with this accessory"
Kent, this can be caused by a bad cable, an incompatible cable, a different docking station, or a bad dock connector. You did not tell us if you changed anything in how you charge you iPhone. I would try an AC adapter and a known good cable and see what it gives you. If your known good cable and a good AC adapter still tells you he same thing, I suggest to replace the dock connector. Make sure that you have the right cable....:) anyhow, hope this helps, good luck.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 349
2 Comments
ended up being the charging cord, dont understand it cause the charging cord work on 2 other iphones, thank ya very much !!!
by Kent
Good Job, that is where the trouble usually starts.
by oldturkey03
