Toyota released the 2002-2006 Camry XV30 series as a larger sedan in September 2001 for the 2002 model year.
How do I reset check engine light?
How do I reset my check engine light?
Add a comment
1 Answer
Most Helpful Answer
Hi @steve78064
The check engine light will be gone once you find and fix the problem that has caused it to come on.
It is on telling you that there's a problem with the engine that needs your attention.
The easiest way to find out what the problem is, is to get the OBDII port in the vehicle scanned with an appropriate scantool to see what DTC code (Diagnostic Troubleshooting Code) has been stored. The code tells you what the problem is.
If you're in the USA major auto parts retail stores e.g. AutoZone, PepBoys, O'Reilly Auto Parts etc, do this for free apparently.
Score 1
Add a comment
Add your answer
Steve will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 108
