The Airpods Pro 2 with a USB-C charging case has improved dust protection, faster charging capabilities, and the ability to use Lossless Audio with Apple Vision Pro. It also has Adaptive Audio, Conversation Awareness, and Personalized Volume.
Left side is not working
My airpod got on water and i clean and drain it and it work for a weak but now the left side is not working what shaĺl i do
Score 1
1 Comment
It fell down only
by
Add a comment
Most Helpful Answer
Unfortunately, there is not much that you can do, AirPods are generally impossible to open and repair without causing damage to the plastic case.
Water damage happens when corrosion from minerals from your water make contact with the circuit boards of your earphones. You may have to throw away your left earphone since the damage has already happened. Sorry for your situation :(
Score 2
Add a comment
Well I will suggest you to checkout the following video: https://www.youtube.com/watch?v=Z77mEmP1...
Add a comment
Some time only I used both AirPods but most of time I used only one side AirPods. One day when I used both AirPods that time I realised one of them AirPods it’s not working.
Add a comment
I have the same problem only my left ear pod is not working also I didn't drop in water
It was kept on a computer desk and will use it once a week, I tried cleaning the ends and charge ends but nothing works, the right side works and charges asusual
Add a comment
No
It fell down only
Add a comment
It fell down
Add a comment
Lift side no working
Add a comment
Add your answer
saba beyene will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 28
Past 30 Days: 70
All Time: 635
