The Makita 9554NB is a corded electric angle grinder designed for grinding and cutting applications, featuring a 710W motor, 4-1/2 inch max disc diameter, and 11,000 RPM no-load speed. This model has a black and blue design, with dimensions of 10-5/8 x 5-1/8 x 4 inches and a weight of 4.6 lbs.
no function and overheating
my ginder is not functioning and overheating, how to fix this?
Add a comment
1 Answer
Most Helpful Answer
@hammedtalus1335 not quite sure how this "not functioning and overheating" works, since if it is not functioning it should not be overheating. Now, it is possible that your grinders motor is still pulling amps but not rotating because of a seized bearing. You will have to take your grinder apart and have a look at the bearings. It is fairly common that the bearings either wear out or get gummed up by debris with heavy use of the grinder.
To work on your grinder use something like this video Once you have it apart post some well focused images of what you find out, with your question. That way we can see what you see and hopefully help you out further. Adding images to an existing question
While you work on your grinder, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Score 1
Add a comment
Add your answer
Hammed Talusan Abdula will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 18
All Time: 187
