The Lenovo IdeaPad Flex 5-1470, manufactured in 2017, features a 14 inch touch screen display which folds 360 degrees into a 2-in-1 convertible laptop. Model Name: 80XA Model Number: 80XA0001US
Only a few select buttons do not work
Buttons, "1", "2", "Q", "`", "esc", and sometimes WASD and 3,4. but the rest of the keyboard works fine
Add a comment
1 Answer
This issue usually means a keyboard matrix or ribbon-cable problem, not software. The affected keys (Esc, `, 1, 2, Q, WASD) sit on the same keyboard column, so a damaged trace, liquid residue, or loose connector can cause selective failure. First, test with an external keyboard—if it works, the OS is fine. Power off, open the device, reseat and clean the keyboard ribbon cable with isopropyl alcohol. Check for corrosion or bent pins. If cleaning doesn’t help, the keyboard membrane is damaged and the only reliable fix is keyboard replacement.
Add a comment
Add your answer
evanjd will be eternally grateful.
Past 24 Hours: 16
Past 7 Days: 18
Past 30 Days: 18
All Time: 18
