A phone released by Freeyond is meant to be affordable and stylish, while not compromising on quality. It can often be found in many online retail stores from $70-$100 USD.
How to make your phone ringing
Add a comment
1 Answer
Hi Ngalula!
To get your Freeyond F9 to ring again, you should check the following sound settings:
1. Check the Volume Buttons
  • Press the Volume Up button on the side of the phone.
  • Look at the volume slider that appears on the screen. Tap the icon (usually a bell or speaker) to switch from Vibrate/Silent back to Ring mode.
2. Check Sound Settings
  • Go to Settings > Sound (or Sound & vibration).
  • Make sure the Ring volume slider is turned up.
  • Tap on Phone ringtone to ensure a ringtone is actually selected and not set to "None."
3. Check "Do Not Disturb"
  • Swipe down from the top of the screen to open the Quick Settings.
  • Check if Do Not Disturb is turned on. If it is, turn it off, as this silences all calls.
4. Check for Headphone Mode
  • If your phone thinks headphones are plugged in (when they aren't), it might not ring through the speakers. Try plugging and unplugging headphones or cleaning the jack/USB port.
Add a comment
Add your answer
Ngalula Katembo will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 5
Past 30 Days: 5
All Time: 5
