Install new RAM problem
See image content:
Add a comment
Chosen Solution
@eijuvp6xzseev2s the RAM module in your picture is a DDR4 2400MHz RAM module. Your HP ZBook Fury 15 G8 system standard for RAM is 3200MHz. Using the memory module shown in your image, will significant slow down your computer. I would strongly advice against using it. Consider it incompatible. ¯\_(ツ)_/¯
Score 2
Add a comment
Hi, would you mind explaining what problem you're experiencing?
- Is it that the ram does not fit?
- Does the laptop not boot with the ram?
- Is the ram stick broken?
If you need instructions, you can follow this guide for you laptop HP ZBook Fury 15 G8 Thermal Paste Replacement until Step 3, were the ram will be accessible.
1 Comment:
Thanks, may it cause blue screen problems, so I removed it.
by
Add a comment
Add your answer
topeng00 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 14
Past 30 Days: 30
All Time: 315
